Wave - cut and filleting fails
All  1  2-4
The problem is on your wave.
If you take the edges of the wave, and join them, you could next see the points (show points).
The density of the points is problematic.
Reconstruct this curve and extrude it to redo the wave.
Next, you will not have the problem with filleting.
Have fun...
10565.3 In reply to 10565.1
Hi Mala, I noticed that fillets of some radius values seemed to work but I noticed some anomalies in the generated fillets in these areas here:
So I closely examined that area of the model and I found the "side wall" surface folds back over itself in a small zone there, like this:
I think there is another area like that on the other side.
This probably needs to be corrected in the original curves used to construct this before doing flow, etc... on them.
10565.4
Michael..thx very much. You were right.
I rebuild the spline. It came out of Indesign. It was not properly at all.
Best regards, Mala
Show messages: All  1  2-4
