Changing colours of those icons
10562.1
Hey everyone, I've just started using MOI and tried to modify the GUI to be more modern and professional in its appearance. I love how flexible it is but dislike how many steps it takes to make those changes.
I'm using the dark grey theme by Cody and made this even darker by changing colours in the moi.css, so MOI looks closer to Cinema4D R25, Blender 3 and Win10 Dark Mode.
I've also installed the sweet extra UI bar by Max Smirnov.
The issue is that some of his icons are still black, while I'd love to have those white, so you could still see them against the dark BG. See screenshot attached.
Where can I locate those?
I've looked into the CommandBar.htm, searched C:\Program Files\MoI 4.0 and C:\Users\Username\AppData\Roaming\Moi for any png or svg files, but I could not find those icons anywhere. It's weird.
Thanks in advance,
Cheers,
Cornel
Size: 385.1 KB, Downloaded: 80 times, Dimensions: 2559x1439px
10562.2 In reply to 10562.1
Max used "base64" in his UI to code those icons.
So you can find them as a line of base64 inside of his UI config files...
He explains you can use an online system to get base64 code from your image.
Maybe go back to max's originating post to gather the proper info.
10562.3 In reply to 10562.1
Hi Cornel, yes like Burr writes above the icons for Max's CustomUI mod are embedded in the .js files that you copied into the startup folder.
There is some description on how to edit those to load a PNG image file here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9138.12
10562.4
Thanks guys,
I had no idea those were in base64.
I'm good from here.
