ORGANIC MODELLING IN MOI SUB D
All  1-2  3-12
LineWeb for help to make Box Modeling :)
Draw curves
Rebuild say 10 points
Line Web Lines or polylines: 10 points (order of selection is important! )
Kill curves
Loft "Lines"
Kill Lines
Select faces : Extrude with "Keep Separate"
Boolean Union
Subdivide
And if you save your object in OBJ
You can use the free funny Spline for some cool things in seconds without some efforts! :)
Click on the little object ;)
And of course Zoom, Rotate, Move...
EDITED: 21 Jan 2022 by PILOU
10560.4 In reply to 10560.1
Nice work Alex. I always enjoy seeing what people make with the SubD tools in MoI. It's good to have the SubD option for those "organic" shapes, and really powerful when those shapes are combined with NURBs objects.
10560.5
HI Pilou,
Thanks for your workflow method looks even simpler and great for simple shapes, the workflow I presented keeps the subd object point control intact so that the shape can be sculpted in MOI.
EDITED: 4 Jul 2022 by ALEXPOLO
10560.6 In reply to 10560.5
It was just a complementary little method! :)
else
10560.7
I Firstly drew the primary blue outer shape in polylines. Then I manually drew in the black body dividing lines adding more where I though I may need more control over points to manipulate the shape. I then deleted the outer line and redrew the polyline outer to match the inner divisions so all the divisions ended as quads. Same process for the legs.
I have rhino7 with subd but love the simplicity of the MOI tool set so I took inspiration from this video,
https://www.youtube.com/watch?v=EaB548qwpm4
10560.8 In reply to 10560.7
Thx for the info!
Yes method shawn on Rhino is classic Box Modeling...
You can Make exactly the same with the 4 "rustical" tools given by Max Smirnov inside Moi...
SubDivide, SSplit, SBridge, Sscale sure maybe not so speedy than Blender or special Poly Modeling prog
Here move down the "inset face" is made by a simple "extrude" (not shown on this video)
10560.9 In reply to 10560.3
I have posted a NE example based on your method to instagram:
https://www.instagram.com/p/CZD7M53rKUR/
10560.10 In reply to 10560.9
@ James Perfect illustration & simulation! :)
your Nodes expertise is a magic breeze!
Your Instagram site is a monument like was Jotero (Torolf) (Moi user time tot time)
http://www.evolution-of-genius.de/gallery/default.htm
https://www.instagram.com/joteromathart/
Remember what TopMoP can do! ;)
images 4 5 6 7 ...
https://issuu.com/frenchy_pilou/docs/topmod
I am always amazed by this Issuu system! Works more ten years after! :)
EDITED: 23 Jan 2022 by PILOU
10560.11 In reply to 10560.10
I have a 2.444 (2.5) ;)
From here i suppose! The creator!
http://people.tamu.edu/~ergun/research/topology/download.html
Show messages: All  1-2  3-12
