Make 2D 4 view
All  1-4  5-7
10551.5 In reply to 10551.3
Hi BlackBird,
> Yes, but it uses the "Projection method 3".
> In Europe we use the "Projection method 1".
> So the views are swapped.
You can modify the script to do this by finding line number 33 in make2D4Views.js which has this:
var views = [ 'Top', '3D', 'Front', 'Right' ];
and change it to this instead:
var views = [ 'Right', 'Front', '3D', 'Top' ];
10551.6 In reply to 10551.5
hi
something i discovered by accident
the 3D view is the current view when calling the script
( and not a parallel or isometric view )
Chri
Size: 83.8 KB, Downloaded: 90 times, Dimensions: 1180x690px
10551.7 In reply to 10551.6
Hi Chri,
Yes that's how it is set up to work, same as the regular Make2D command and also same as the Make2D command in Rhino as well.
If you want it to generate a parallel view you need to set the 3D view to be a parallel projection before running this command.
Show messages: All  1-4  5-7
