circular gear with a linear gear
All  1-17  18-20
10548.18 In reply to 10548.14
Hi Burr,
I found this https://en.m.wikipedia.org/wiki/Involute_gear which shows the constant velocity the involute shape produces.
So I think the answer is inverting the tooth shape without inverting it’s axis (origin of construction)will result in a inconstant velocity thro the tooth meshing.
Barry
10548.19 In reply to 10548.18
Hi Barry,
I agree. But this still misses my point.
If you search and look at all the models and such, they are just made with "negative" cutouts.
So, my point is the tooth profile should not be a negative, but inverted.
Inverted would include all the knowledge, math and calculations to create involute meshimg, just like on opposing module spurs... (obviously a recalculation. Not just simple coordinate inversion. So my image is simplified.
I was looking for the wiki or blog on how to calculate the inversion...
10548.20 In reply to 10548.19
Have you tried using the image search option to look for pictures with calculations?
Just typed in "How is rack pitch calculated?" with image search results and found several images with calculations.
Like:
https://www.sdp-si.com/resources/elements-of-metric-gear-technology/index.php
Show messages: All  1-17  18-20
