CNC engraving text in sterling silver
 1-15  16-35  36-37
10542.36 In reply to 10542.34
Hi Gunter,
Here is the text, modeled with the extrusion angle you pointed out in your last file.
I used the centerline from the original file I posted that i got by converting a Vcarve toolpath into geometry. I flattened it and then set it at the depth of the tool you posted. Then just hand modeled the sidewalls to simulate an extrusion...They are solids. But they won't help you in Vectric..
Anyway........
10542.37 In reply to 10542.30
Part 3.
Final.
Frame.
1 Select the center lines and from the front or right view move them to the desired distance.
2 From the '3D' view, use the 'Lines/Line' command to draw lines as in figure "III_1".
Surfaces.
1 Select the triangles and apply the "Planar" command to them
2 Select 4 lines as in the "III_4" image and apply the "Network" command to them.
3 Using the "Sweep" command build a surface like in the image "III_5".
4 Select the 2 surfaces, image "III_6", and apply the command "Boolean/Merge" to them.
5 Remove the unnecessary parts.
6 Build the remaining surfaces with the command "Network" as in image "III_7, III_7_2".
7 Combine the constructed surfaces with the "Boolean/Union" command.
8 Unblock the oval and apply the "Plamar" command to it.
9 Select the resulting surface and apply the "Boolean/Diff" command, select the constructed surfaces and complete the command.
10 Hide the plane of the oval.
11 Select the oval and apply the "Extrude" command to the desired height.
12 Remove the top part.
13 Return the hidden part and use the "Boolean/Union" command to merge the desired surfaces.
https://disk.yandex.ru/d/9I0HXeZKOr5h9w
This is only one of the options, and not the best, try and feel free to experiment.
That's all.
Size: 190.2 KB, Downloaded: 25 times, Dimensions: 1920x1078px
Size: 338 KB, Downloaded: 29 times, Dimensions: 1920x1078px
Size: 184.3 KB, Downloaded: 26 times, Dimensions: 1920x1078px
Size: 184 KB, Downloaded: 21 times, Dimensions: 1920x1078px
Size: 177.2 KB, Downloaded: 23 times, Dimensions: 1920x1078px
Size: 256.4 KB, Downloaded: 24 times, Dimensions: 1920x1078px
Size: 234.1 KB, Downloaded: 26 times, Dimensions: 1920x1078px
Size: 148.6 KB, Downloaded: 26 times, Dimensions: 1920x1078px
Size: 237.7 KB, Downloaded: 24 times, Dimensions: 1920x1078px
Size: 296 KB, Downloaded: 26 times, Dimensions: 1920x1078px
Size: 345.7 KB, Downloaded: 25 times, Dimensions: 1920x1078px
Size: 269.8 KB, Downloaded: 29 times, Dimensions: 1920x1078px
Show messages:  1-15  16-35  36-37
