Extend selection of connected curves
All  1  2-5
10540.2 In reply to 10540.1
Maybe this one select all curves joined...without certitude...tested ...seems not! :(
script:/*Loop selection*/moi.geometryDatabase.selectLoop();
But between two 3D curves you can use Blend who connect these 2 curves! :)
10540.4 In reply to 10540.1
Hi Zooen,
> As there is the script "Extend selection of edges" there is "Extend selection of connected curves".
Not that I'm aware of. You can select a big pile of curves and use the Edit > Join command to glue together the pieces that are touching each other end to end though.
10540.5 In reply to 10540.4
Thank's for information.
- Zooen
Show messages: All  1  2-5
