Albert Karlen's Hourglass_12
 1-14  15-21
10536.15 In reply to 10536.11
Hi Barry,
But yes of course! I was so focused on modeling that I didn't bother to seriously study how it worked.
Oh dear! at my age...!?!/###/!?!
Well, the screw is not an Archimedean screw. It is, as you say, an "elevator screw". The Archimedean screw is tilted (dixit Wikipedia)
Barry> the screw turns the hourglass is motionless.
In Albert Karlen's original hourglass, the screw is integral with the support (notches on the upper and lower parts of the screw). So would there still be a design problem?
But in fact, it may be a prayer wheel for an unknown deity!
- Zooen
EDITED: 27 Dec 2021 by ZOOEN
10536.16 In reply to 10536.15
Hi Zooen,
have looked at the 3D of Albert Karlen's Hourglass_12 and there's an option for section analysis so you can see the elevator screw.
It looks like the elevator screw is stationary and mounted to outer frame and the hour glass pivots around it.
So don't think it's motor driven just rotated by hand thus elevating the balls.
Hope this helps.
Barry
Ps are going to make one ?
10536.17
Hi Zooen,
You might also like to look into the more modern application of this concept, called a ball screw and used in precision locating, for example machine tools.
https://en.wikipedia.org/wiki/Ball_screw
--Larry
10536.18 In reply to 10536.16
Hi Barry,
In my opinion, the screw is integral with the support and it is the hourglass that we turn by hand. Maybe my en / fr and fr / en translations are playing tricks on me!
Here is the answer of Mr. Albert Karlen (on the site the area of the wood).
to Pilou's question: How does the Archimedean screw turn? by hand or by a motor, or simply by turning, or ...?
The screw does not turn, it is the hourglass which turns around the screw which it is integral with the support, in the state it is done manually but one can imagine adding a motor ...
- Zooen
10536.19 In reply to 10536.16
Barry,
I tried to reply to your private message, but my PM won't send (it is stuck in "outbox"). Not sure what the issue is, but thought I'd try posting here instead.
I have attached NOD file based on your's.
Is this what you needed?
EDITED: 29 Dec 2021 by JFH
10536.20 In reply to 10536.19
Hi James,
thank you works great.
I have added the option of duplicating and rotating the sweep to give a 2 start spiral.
Also an offset option of the revolved curve thus to retain the balls.
Finally boolean difference to complete it all in the Nodeditor.
Anyway again many thanks.
Barry
Happy new year.
Edit added second shape.
EDITED: 30 Dec 2021 by BARRY-H
Size: 241.5 KB, Downloaded: 74 times, Dimensions: 800x600px
Cool! :)
Show messages:  1-14  15-21
