EditCenterPosition
All  1  2-3
10529.2 In reply to 10529.1
Hi Zooen, there is a script for that here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6925.167
Usually you can use the regular Transform > Move command to place an object's bounding box center at a specific location. But that script may be useful if you want to change the value of just one coordinate only.
10529.3 In reply to 10529.2
Thanks Michael for the reminder on "Transform> Move command".
> This script can be useful if you want to modify the value of a single coordinate.
Yes it is for this function that I used it and also to check the position of objects compared to their center of mass (of gravity, or surface) according to the type of object.
Following that I wanted to know how I could put select objects instead of Select objects to move. This forced the boon that I am to do a little work on the script.
"Move select prompt" is replaced by "PlanarSrf select prompt" which results in "Select objects".
Ha! Ha! you have to be retired to have fun doing things like that!
I'm sorry, but I still have the same translator (a certain gogol) who translates "Béotien" by boon or boozy ...
- Zooen
EDITED: 16 Dec 2021 by ZOOEN
Show messages: All  1  2-3
