Moi3d to Enscape
All  1  2-3
10516.2 In reply to 10516.1
Hi Stardust, I'm not familiar with Enscape, but my guess would be that you could probably export out from MoI to an .obj file and then import that into Enscape.
As Enscape works directly with Revit, SketchUp, Rhino, ArchiCAD & Vectorworks
I suppose you can export also from Moi in 3DM, SKP...3DS, DXF...
(not tested because I have not Enscape! :)
In other side Only the file formats; *.gltf, *.obj or *.fbx can be imported to the Custom Asset Library of Escape
so FBX can be used ;)
But...if it is possible to import models with a file format of OBJ, FBX, and GLTF. It is recommended that you import low polygon models with less than 20,000 triangles !
EDITED: 26 Nov 2021 by PILOU
Show messages: All  1  2-3
