Dimensions in just Inches (or perhaps a request?)
All  1  2
10512.2 In reply to 10512.1
Hi makingStuff,
> 1. Is it possible to have measurements in just Inches? No mention of Feet. So a linear
> dimension might show 14 ½", rather than 1' 2 ½".
Sorry no there isn't a way to do that currently. I'll see about adding it in for a future version.
> While I can add the " symbol to each dimension, there doesn't appear to be
> a way to apply this as a default.
No there isn't a way to set the default initial text, the reason why is that different dimension types have different initial text values like a radial dimension has R<> as its initial text value, linear dimensions have <> and text and leaders have blank. So it was not going to work to have just one default text value for all annotations, there would need to be separate defaults for different types. I'll see about adding that in as well though.
One way you can hack it in currently though is to modify the command script for dims, you would do that by editing the file DimLinear.js in the install's commands folder and near the end before the call to factory.commit(), put in:
factory.getCreatedObjects().setProperty( 'text', '<>"' );
factory.commit();
> Nor to show fractions for the Decimal unit.
That's normal though, because decimal display specifically means to not have fractions.
Show messages: All  1  2
