Shortcut for renaming
All  1-14  15-20
10510.15 In reply to 10510.14
Ok, I understand. Thank you very much.
Iwan
10510.16 In reply to 10510.15
Hi Iwan, here's an attempt for an "edit or create" style shortcut.
Copy the attached file EditOrCreateStyleDialog.htm into the appdata commands folder.
On Windows you can find the Moi appdata folder by typing Win+R to bring up the Windows "Run" dialog and then type in:
%AppData%\Moi\commands
On Mac from a Finder window, go to the menu and pick Go > "Go to folder" and type in:
~/Library/Application Support/Moi/commands
Then set up a shortcut key for opening up the dialog and for the shortcut key put in:
script: /* Edit or create style */ var dlg = moi.ui.createDialog( 'moi://commands/EditOrCreateStyleDialog.htm' ); dlg.window.doModal();
10510.17 In reply to 10510.16
Thank you very much, I will give it a try.
10510.18 In reply to 10510.17
Hi Michael, it works very well. I have one last request.
1) I select an object, I run the command and I put it in a "red" style.
2) I select another object, I run the command and I also put it in a "red" style.
Is it possible to put the second one in the same "red" style as the previous one?
And to update the colour if it is modified?
This is the case for the manipulation of object names.
With this script :
script: /* Edit object name */ var pp = moi.ui.propertiesPanel; if (pp.show && pp.numSelectedObjects > 0) { pp.editName(); }
1) I select an object (or surface), run the script and name it "01".
2) I select another object, I run the script and name it "01" too.
I do not have in the name hierarchy twice the name "01", but my two objects "01" are in the same place.
Thanks very much,
Iwan
10510.19 In reply to 10510.18
Hi Iwan,
Please try with this updated version attached here.
10510.20 In reply to 10510.19
It works very well. It's great. It will make my work much faster. I often have a lot of materials (styles) to assign to my 3D.
Iwan
Show messages: All  1-14  15-20
