measuring tool
All  1-3  4-5
1051.4 In reply to 1051.1
Measurement tools in MoI would be nice.
I use this tool a lot on all my graphics programs:
http://iconico.com/caliper/
It has a nice feature where you can calibrate to custom units. For example, you draw a line that should be 5mm long. Adjust the caliper to match the line and set it to read 5. Now other geometry can be measured directly in mm.
This tool is also nice for measuring lines positioned at an angle (grab the caliper and it rotates).
Ed
1051.5 In reply to 1051.3
Hi Juan,
> It is this way what I need to measure as I make it in Rhino
> also place the file of you line constructive but I don't eat to activate it with quick keys
Do you mean that you tried Petr's measure command but it isn't working for you? After you copy the 2 files into the \commands sub-folder underneath MoI's main program folder, you need to add a keyboard shortcut. You can do this under Options / Shortcut keys - add a new entry there and for the command enter "CustomDistance".
> Another question is like they made a variable fillet in the violin head.
You mean the violin shape that Marc was just showing here: http://moi3d.com/forum/messages.php?webtag=MOI&msg=1050.1 ? I think he used a sweep for making that - MoI does not currently have a variable radius fillet, but that is also something I want to add in later as well.
Show messages: All  1-3  4-5
