measuring tool
All  1  2-5
1051.2 In reply to 1051.1
Hi Juan, I expect to add a set of "analyze" tools in version 2.0, including length and distance tools.
For now one way is to draw a line and watch the distance control in the bottom toolbar, it will show you the distance to the previous point. You can also activate distance constraint by entering a distance there.
Petr also has made a custom command for measuring a length, you can find that at his page here: http://kyticka.webzdarma.cz/3d/moi/ , look for "Measure Distance".
1051.3
Hi Michael:
Thank you for your attention
It is this way what I need to measure as I make it in Rhino
also place the file of you line constructive but I don't eat to activate it with quick keys
Another question is like they made a variable fillet in the violin head.
Best regards
Juan Galvan
1051.4 In reply to 1051.1
Measurement tools in MoI would be nice.
I use this tool a lot on all my graphics programs:
http://iconico.com/caliper/
It has a nice feature where you can calibrate to custom units. For example, you draw a line that should be 5mm long. Adjust the caliper to match the line and set it to read 5. Now other geometry can be measured directly in mm.
This tool is also nice for measuring lines positioned at an angle (grab the caliper and it rotates).
Ed
1051.5 In reply to 1051.3
Hi Juan,
Do you mean that you tried Petr's measure command but it isn't working for you? After you copy the 2 files into the \commands sub-folder underneath MoI's main program folder, you need to add a keyboard shortcut. You can do this under Options / Shortcut keys - add a new entry there and for the command enter "CustomDistance".
You mean the violin shape that Marc was just showing here: http://moi3d.com/forum/messages.php?webtag=MOI&msg=1050.1 ? I think he used a sweep for making that - MoI does not currently have a variable radius fillet, but that is also something I want to add in later as well.
Show messages: All  1  2-5
