Fillet problem
All  1-6  7-16
10508.7 In reply to 10508.6
Hi Tony, shapes that look completely melted and smooth throughout without any distinct separate parts can often be done better in a sub-d modeling program rather than in a CAD program.
One thing you could experiment with though is cutting away some more empty space between the pieces and using the Construct > Blend command to put in a blend surface:
https://moi3d.com/4.0/docs/moi_command_reference7.htm#blend
I have said "Joint" in my above post : it's the French word for Blend! sorry...
10508.9 In reply to 10508.8
Hi micheal
I tried as you told me and I managed to get this result.
I will also try with the last tip.
Size: 123.6 KB, Downloaded: 74 times, Dimensions: 1049x995px
Cool result!
10508.11 In reply to 10508.6
Hi Tony, so for blending your current shaping is not good for it because the round part has such a hard change in direction in a small area here:
A blend surface is going to make itself be smooth to that and it's going to need space for that so you'll be limited to something like this:
To make it larger you would need to adjust the shaping of the round part, it needs to be something more like this where it's not such a severe change in direction between the pieces:
10508.12 In reply to 10508.1
Tony -
I agree with Michael that large "melted" surfaces are difficult to join with fillets and continue to look smooth.
I approached this model using a Network consisting of 4 open red curves and 5 closed blue curves.
Rendered in Keyshot.
10508.13 In reply to 10508.12
Thanks Ed Ferguson
Great job !! .... I'll try to do it like this ;)
10508.14
Different approach whit curve projection on central surface and blend with arm but trimmed a little
Variable Fillets
10508.16
Thanks Guys for support!!
Show messages: All  1-6  7-16
