3D print + Raspberry Pi + moi 3d little project 02
10505.1
Hello here the second Raspberry pi case project.
Here if you want the STL 3D model and support me
Size: 333.1 KB, Downloaded: 102 times, Dimensions: 2032x1524px
Size: 382.2 KB, Downloaded: 78 times, Dimensions: 2032x1524px
Size: 790.1 KB, Downloaded: 79 times, Dimensions: 2032x1524px
Size: 779 KB, Downloaded: 80 times, Dimensions: 2032x1524px
Size: 858.8 KB, Downloaded: 83 times, Dimensions: 2032x1524px
Size: 967.8 KB, Downloaded: 71 times, Dimensions: 2032x1524px
Very nice design and result! Have you tried the heat-set threaded brass inserts for machine screws? I use them a lot on 3D printed projects.
10505.3 In reply to 10505.2
Hello Ed. Yes I did bought them but i did not test them properly. I have few question do they work well on PLA? Is the small that bad when the plastic melt?
Frank -
Here is a box I designed in MoI and printed in PLA in 2018. Scroll down to see the brass inserts.
http://moi3d.com/forum/index.php?webtag=MOI&msg=8944.1
They work great in PLA and are very strong once you have the hole size calibrated for your printer. I printed a test piece with holes in various sizes near the nominal size to try them out. They take 3 seconds to set using a pointed tip soldering iron. I don't notice any smell.
10505.5 In reply to 10505.4
Really nice project!! Super precise and I see the brass give a nice finial look ;) good job!
