Hello congratulations on your hulls, from what I see you use these lofts of longitudinal lines, but so it becomes complex to predict what the hull can be because I notice that the curve generated has a tension that moves away from the construction lines,
In fact, I find it difficult to use a few curves and I often have to create many sections to avoid this inconvenience with which I encountered this complication, I tried various techniques, but still today I find some critical points and it is difficult to obtain the continuity of the surfaces with simple loft or sweep rails.
However, you have found an effective and quick way to make new hulls.
I, on the other hand, must always use stations and profiles, having to work on CAD drawings, where the shapes are binding.
