Seemingly no way to match an image to a rectangle
All  1-6  7-8
10498.7 In reply to 10498.6
Hi pior, image embedding is not on by default because it duplicates data and increases file size.
I'll see about putting in an option to make it be turned on by default though.
10498.8 In reply to 10498.7
Hello !
I think there are multiple solutions really, the point being that imho the priority should be put on error prevention - in this case making sure that the default behavior doesn't cause any loss of work. I would say there are two ways to do that (hence 4 permutations total) :
- Making the tickbox unmistakably visible when interacting with the image tool (regardless of its default setting) ;
- Setting the default behavior to embeded, as the argument could be made that file size (especially for just a small set of images) is of much less importance than making sure that the user doesn't lose work when moving files around on or sending a file over the network. I can certainly confirm that I have already lost some image planes that way in the recent past ...
Of course an .ini setting that advanced users could enable could be an acceptable solution ... but with the cavehat of potentially losing a few images first, until the user starts searching for a workaround.
Anyways ! Thanks a lot for the assistance as always. I am obviously influenced by the Blender UX here, in which the settings is set once and for all and never needs to be touched again (it even keeps the initial link to the image, meaning that it is even possible to refresh the embedded pictures as long as they are still present on disc). A great solution really.
EDITED: 5 Nov 2021 by PIOR_O
Show messages: All  1-6  7-8
