Save image from MOI
 1-18  19-38  39-43
1049.39 In reply to 1049.5
Dear ALL!
script: /*! Screenshot Moi Strg+G*/var v = moi.ui.getActiveViewport(); if ( v != null ) { moi.view.lineWidth = 4; v.renderToClipboard( 5300, 3560 ); moi.view.lineWidth = 1; }
I have been using this feature for many years without any problems. Now we have noticed on a new PC that nothing or only a transparent background is inserted from the clipboard. What could be the reason for this?
Best Regards,
Franz
1049.40 In reply to 1049.39
Hi Franz, it is likely to be a problem or limit of maximum texture size in your new machine's video driver.
You could try updating your machine's video driver or lowering the width and height of the requested image down from 5300, 3560 .
What happens if you use this for example:
script: /*! Screenshot Moi Strg+G*/var v = moi.ui.getActiveViewport(); if ( v != null ) { moi.view.lineWidth = 4; v.renderToClipboard( 1000, 1000 ); moi.view.lineWidth = 1; }
1049.41 In reply to 1049.40
Thanks Michael for the quick reply.
Unfortunately, it has nothing to do with that, but maybe it's a setting in Irfan View.
Should Java Script be installed?
My colleague works with Windows 11.
Best Regards,
Franz
1049.42 In reply to 1049.41
Hi Franz, do you mean that test shortcut above with a 1000 x 1000 pixel size still doesn't work?
And updating the video driver didn't make any difference either?
MOI has JavaScript built in, it doesn't need to be installed separately.
1049.43 In reply to 1049.42
Hello!
We found the error. It is probably due to the new version of Irfan View.
We have now installed the slightly older version and everything is working again.
“iview452_x64_setup.exe”
Thank you very much,
Franz
Show messages:  1-18  19-38  39-43
