Hull design (Supply Vessel)
All  1-7  8-13
10486.8 In reply to 10486.7
Vu mon âge avancé, je n'ai plus que ça à faire! ;)
10486.9 In reply to 10486.5
Hi Eryon,
> No problem for the tuto but it may require some space on the Server.
> I have no idea about the rules, perhaps someone (Site admin) can clarify.
Each forum user can have up to 50MB of attachments hosted directly on the server. If you post .jpg images that's enough space for quite a lot of those but things like videos will fill up that space pretty quickly. If you need more space you'll need to use some kind of file sharing service and put in links to it instead of directly uploading the files here.
10486.10 In reply to 10486.9
Thanks Michael. I think for a tuto it is fairly enough space.
Eric
10486.11 In reply to 10486.2
Bonjour Pilou,
Question bête.
- Y a-t-il une fonction qui permet de changer la couleur d'un -seul- objet sur un calque (différent de ce dernier) ?
- Existe-t-il un moyen d'arborescence pour organiser les calques en sous-calque ?
Désolé de vous embêter avec tout ça.
Cordialement
Eric.
p.s. Dans quelle région du pays êtes-vous ?
10486.12 In reply to 10486.11
Il vaut peut-être mieux poser les questions en français sur le forum francophone! ;) http://moi3d.com/forum/index.php?webtag=MOI_FRANCAIS
I don't believe there are yet some layers and arborescence system inside Moi3D!
Just Names, Colors but any selection can have any Names & Colors !
It's sufficient for tricky intricated selections who are not possible in classical layer modes! :)
10486.13 In reply to 10486.12
Thanks Pilou
Show messages: All  1-7  8-13
