Fixing of letters
All  1-3  4-7
Both objects Letters + Base must be solid !
Letters must overflow inside >Base for not have some problems! :)
10481.5 In reply to 10481.1
Hi Bodo-Lutz, one issue is that there is an area inside your model where the "wall thicknesss" is pinched down to 0, that may cause some problems with volume operations:
10481.6 In reply to 10481.1
Hi Bodo-Lutz, please try with this attached version it should boolean union ok now.
I used Edit > Separate and Edit > Join to get rid of the naked edges in the model to make it a solid (although there is still the 0 thickness "pinch point" which may be a problem for other things down the line) and also stretched out the text so that it pushed a little distance down through the model instead of skimming right along it.
10481.7 In reply to 10481.6
Many thanks for your help
Good night!
Bodo-Lutz
Show messages: All  1-3  4-7
