Fixing of letters
All  1  2-7
10481.2 In reply to 10481.1
I think you have something wrong in your main object.
It's a joined surface and the boolean operation has problem with this point.
You can view where the problem is located with a SelectNakedEdges script.
Your text is not included in the object too.
10481.3 In reply to 10481.2
All the text was added to this model part afterwards, but together and at once.
My question is why not all letters will go in contact with surface of the main part. The "x" in this line and the rest of them are connected without any difficulty.
BLS
Both objects Letters + Base must be solid !
Letters must overflow inside >Base for not have some problems! :)
10481.5 In reply to 10481.1
Hi Bodo-Lutz, one issue is that there is an area inside your model where the "wall thicknesss" is pinched down to 0, that may cause some problems with volume operations:
10481.6 In reply to 10481.1
Hi Bodo-Lutz, please try with this attached version it should boolean union ok now.
I used Edit > Separate and Edit > Join to get rid of the naked edges in the model to make it a solid (although there is still the 0 thickness "pinch point" which may be a problem for other things down the line) and also stretched out the text so that it pushed a little distance down through the model instead of skimming right along it.
10481.7 In reply to 10481.6
Many thanks for your help
Good night!
Bodo-Lutz
Show messages: All  1  2-7
