Automatic installation of Moi3D on Linux
All  1-4  5-6
10477.5 In reply to 10477.4
I don't know why it needs these two software, but I'm sure that for moi3d I had to install Gecko and as it says here it needs IE7, for Winetricks it can be useful to install and manage the versions of Windows, in my case the interface of the windows changes and I don't know what it is now but with a Windows version I can better explore the operating system directories, and you can install recent versions of DirectX and OpenGL and various dlls
For the rest I try to investigate better but every time I update WineHQ and open Moi3D I have to wait for the installation of the two components otherwise it won't start.
https://appdb.winehq.org/objectManager.php?sClass=version&iId=7383
10477.6 In reply to 10477.5
Hi pafurijaz,
The thing that says that is from 2007, that's 14 years ago and is no longer correct. That was for MoI version 1 and version 2. Starting with version 3 MoI does not require IE7 anymore.
That's something built in to the standard Wine version, I think since those pieces are large it will prompt you if you want to install them or not. You don't need to install those for MoI to run, it does not use anything from Mono or gecko.
All you need to run MoI is to install standard Wine, no optional components, no gecko, no Mono, no winetricks are required nor are used by MoI.
The other piece that you need though is a good video driver that isn't full of bugs.
Show messages: All  1-4  5-6
