Detach Selection?
All  1-3  4-16
10464.4 In reply to 10464.3
So Just Copy without Move : Name your selection depending of what do you want exactly...
Maybe an image Before /After will be more helping...
You want each face as an object ?
EDITED: 1 Oct 2021 by PILOU
10464.5
Oh, sweet Jesus, thank you!
I kinda need to get into the mindset of this program...
Objects are not objects, but rather a collection of named faces!
Selecting some and giving them a new name does the trick, thank you!
10464.6 In reply to 10464.5
"Name" or "color" (style) ;)
10464.7 In reply to 10464.6
No, the list is titled "objects", not "name"!
This is something totally different and had me confused quite a bit.
But all is sorted now, thanks.
10464.8 In reply to 10464.1
Hi morph3us, it sounds like you've got it sorted out?
Things in MoI do not work quite exactly the same as in a polygon mesh program.
You originally wrote:
> I dont mean a face or edge selection, but the one when you have multiple seperate
> "meshes" in one "object" (not quite sure if I got MoI`s terminology right...) and just
> click once on one of them.
MoI will not normally get in the situation you're describing here where a single "object" could be made up of disconnected islands that don't touch each other.
MoI will automatically separate objects into individual pieces that are separately selectable instead of making that type of result.
So your question is a little difficult to answer since it seems to be based on a situation that Moi already will avoid making.
It might be possible that you've run into some bug where the automatic separating isn't working for some specific situation, if so then it would be helpful to know more details about what you're running into so I can fix it up.
10464.9 In reply to 10464.8
All I can say is that I imported a step file (which I exported from FreeCAD, I dont know which program the model came from originally) and the backplate of my device was on the same object layer as two totally separate buttons.
Unfortunately I can not share the file I am working on, is there a log I can show you or something?
10464.10 In reply to 10464.9
For send a file to Michael : moi@moi3d.com
10464.11 In reply to 10464.10
Thank you, pilou, for the link.
As I stated above, I can NOT share this file.
10464.12 In reply to 10464.11
No problem, only Michael will see it! ;)
10464.13 In reply to 10464.9
Hi morph3us,
So that's a bug, it's not intended that it should work that way.
> you or something?
Unfortunately no, there isn't any log that would help me to figure it out, I really need to be able to test with the actual file to fix file import bugs.
For now for your particular situation you could fix it by selecting the object that has disjoint pieces in it, then use Edit > Separate followed by Edit > Join, that should end up separating the disjoint object out into individual objects.
If I was able to reproduce the problem over here with a test file then I would be able to fix it for v5.
10464.14 In reply to 10464.13
Hey Michael,
I was able to reproduce the behaviour with a really simple self-made model, which I can obviously share with you:
https://mega.nz/file/Rlwk3YRS#CvjDmf1PGjySmlty61QD5qLHD7dXzG4gecF8rlpY7HY
I created two cubes in FreeCAD, which do not touch.
Afterwards I fusioned both of them and exported a STEP file.
Both cubes, although completely separated from another, are coming up as one object in MoI.
Nevertheless, I dont think there is great need to improve this, I can just select the sub-object and rename it - done.
P.S.:
This opens up a whole new topic and I am not sure if you even want to hear it, but I really do not trust your Separate / Join commands.
I import the step files into Cinema 4D after I am done in MoI and all objects I used these commands on have one or another problem.
These range from empty objects (there are no faces / edges in the objects, although their names appear in the object list in C4D),
to broken boolean operations, where all of a sudden I can see the original boolean objects and the booleans, which looked fine in MoI, are incomplete all of a sudden.
So I tend to avoid them until now.
10464.15 In reply to 10464.14
Hi morph3us, thanks for the example file. That is working how it is supposed to though. You end up with 2 separate objects which both have the same name assigned to them.
When objects have the same name, MoI will show only one entry for them in the scene browser objects section so that you can target them as a type of group.
When you select both objects you should see that it's reported as 2 solids:
So you don't need to do any separate/join fixing step for this one, they are already separate objects they aren't one object with disconnected "islands". The objects just have the same name.
Ok, do you have any example files for these problems so I can try to repeat the problem over here? I can't really do much about these just by a kind of general description, I need to be able to reproduce the problem and be able to test different things to try and correct it.
10464.16 In reply to 10464.14
Oh, also you can control how objects with the same name are processed for mesh exports by the setting under Options > Import/Export > "Combine same named objects":
If that is on, then objects with the same name will be all generated into one single mesh object in the mesh file.
If that is off, then objects with the same name will become separate mesh objects in the mesh file.
So if you don't want them combined set "Combine same named objects" off.
Show messages: All  1-3  4-16
