[Help] How Show/Hidden Elephant Window?
All  1  2-4
10463.2 In reply to 10463.1
Hi Kondou, normally the Elephant window is displayed as a dialog box. Do you have some customized UI where you're trying to place it as a docked panel instead of as a dialog?
If so then a first step would probably be to post your customized UI so I can take a look at it and test with it.
10463.3 In reply to 10463.2
dear Michael:
i have try useing a dialog box. but close the dialog box Elephant show the error messing?
I think I can only use hidden on Elephant dialog box. not Close!
10463.4 In reply to 10463.3
Hi Kondou, none of the node editor versions that I have over here have a line of code like you show there.
Do you have a customized version of the node editor? Can you post a .zip file of your node editor directory so I can test with it over here?
What script code are you using to launch the node editor dialog?
Show messages: All  1  2-4
