v4 final DARK UI - does anybody have one that works with v4 final?
All  1-2  3-14
10461.3 In reply to 10461.1
Hi Jabber,
I had the same problem as you and solved it using this theme blow.
It is a modified version of an old theme Michael posted some time ago. I cant remember when it was posted or what was the original highlight color, but I changed it to brown after going through a dark-blue version that i didnt like. Its not 100% consistent or perfect by a long shot, but its not that bad either :-)
If you like to test it you will need to put the 2 files in the zip in your ui folder. Remember to keep a backup or rename the original files first in case you want to go back to the default look.
You can change the background color, grid color, axis color etc in the settings window.
Dinos
10461.4 In reply to 10461.3
that's beautiful and I appreciate the share A LOT!!!
Works fine!
10461.6 In reply to 10461.2
I'm digging your dark theme Death but how did you get that glossy finish on the actual model in the view ports. I'm a total noob at MoI so please bear with me. Thanks
10461.7 In reply to 10461.6
It's one of the lighting item, porcelain, in my the extras menu. There are a bunch of them to chose from.
The UI you see consists of a whole bunch of items and it's a pain to set up, especially for a newby.
I will sit down and describe how to install all of it in an easy way. You will get the whole setup, minus my personal objects, everything else included, along with the extras and scripts. Give a little while and I zip up the UI and instructions.
10461.8 In reply to 10461.7
10461.9 In reply to 10461.2
That is a neat ui setup Death. I'd love something similar to that. I only know how to use the MoiGUI though.
10461.10 In reply to 10461.6
The parameters for lighting settings for making a glossy/matte/reflective type appearance are under Options > View > "Lighting options".
There is a plug-in from Dinos that you can use to more easily switch between different presets:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5222.43
10461.11 In reply to 10461.8
@cad-guy: I uploaded the whole kittencadoodle for you, check this post in the forum:
"Dark Neutral Grey UI Complete with Instructions"
http://moi3d.com/forum/messages.php?webtag=MOI&msg=10465.1
@Art (ARTURBRZUZA): It IS the Moi GUI. You will instantly know how to use it...
10461.12 In reply to 10461.4
Thanks for the kind words Jabber!
Btw, I saw Michael's preview of the official dark theme on a different thread and it looks like he is also going for a brown version :-)
Dinos
10461.13 In reply to 10461.10
Thanks Michael, I'll check it out.
10461.14 In reply to 10461.11
Saw that and downloaded. I'll give it a try when I get home :)
Show messages: All  1-2  3-14
