MoI Trial Version Question with Scripts and Commands
All  1-5  6-7
10448.6 In reply to 10448.5
Hi Dave, you have added them to the correct place, it is normal behavior that you don't see any changes in the UI. You can launch a command you have installed by either pressing Tab once to put focus in the XYZ input control and then type in the command name there, or set up a shortcut key to launch it.
There is a description of this on the FAQ here:
https://moi3d.com/wiki/FAQ#Q:_How_do_I_install_a_plug-in_script.3F
> As I mentioned to Pilou, have seen screenshots of different folks interface and it has extra
> buttons at the bottom for such commands and scripts. This is what I'm looking to duplicate
> for quick easy access.
Those extra buttons are not part of the standard MoI UI, they are added by a UI mod called CustomUI which you can get here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.1
10448.7 In reply to 10448.6
Thanks for the prompt reply Michael.
I'll check out the links you provided below.
Thanks again,
Dave
Show messages: All  1-5  6-7
