MoI Trial Version Question with Scripts and Commands
All  1-3  4-7
10448.4 In reply to 10448.2
Thanks for the reply, but forgive me if I'm not following this correctly. If I hit tab, it bounces between the coordinate, distance, angle, and grid snap button no mater where I click the mouse.
I have downloaded these scripts and commands off the forums. The scripts are just the JavaScript file. The commands have the JavaScript and the HTML file.
I have seen screenshots of different folks interface and it has extra buttons at the bottom for such commands and scripts. This is what I'm looking to duplicate.
Dave
10448.5 In reply to 10448.3
Thanks for the reply, good to know it's not a limitation, but I guess the problem is me. Below is a screen shot of the directory hierarchy.
I have added the other commands (JavaScripts and HTML files) to the Commands folder where the native commands reside. I just added the Script folder under the MoI root directory.
As I mentioned to Pilou, have seen screenshots of different folks interface and it has extra buttons at the bottom for such commands and scripts. This is what I'm looking to duplicate for quick easy access.
Dave
10448.6 In reply to 10448.5
Hi Dave, you have added them to the correct place, it is normal behavior that you don't see any changes in the UI. You can launch a command you have installed by either pressing Tab once to put focus in the XYZ input control and then type in the command name there, or set up a shortcut key to launch it.
There is a description of this on the FAQ here:
https://moi3d.com/wiki/FAQ#Q:_How_do_I_install_a_plug-in_script.3F
Those extra buttons are not part of the standard MoI UI, they are added by a UI mod called CustomUI which you can get here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.1
10448.7 In reply to 10448.6
Thanks for the prompt reply Michael.
I'll check out the links you provided below.
Thanks again,
Dave
Show messages: All  1-3  4-7
