Export nurbs curve details
All  1-2  3-6
10444.3 In reply to 10444.2
Thanks Michael,
I am try to create a script to export geometry to SVG. I’m not really interested in nurbs informations, it will be suffice to have curve tessellation points
10444.4 In reply to 10444.3
Hi miquik, there is an evaluator available to scripts, see the "scripting" section here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8814.1
Or also you can use the factory for the "ArrayCurve" command to generate points at equal distances along a curve, see the ReconstructCurve command for an example:
http://kyticka.webzdarma.cz/3d/moi/#ReconstructCurve
There will likely be SVG support coming for MoI v5.
10444.5 In reply to 10444.4
Thanks Michael,
I would like to implement SVG export anyway now. I almost done, just one thing is missing: can I obtain viewport width/height? I need to create the projection matrix but these properties seem hidden.
10444.6 In reply to 10444.5
Hi miquik,
There are .pixelWidth and .pixelHeight properties on a viewport object, so something like:
var width = moi.ui.mainWindow.viewpanel.getViewport('3D').pixelWidth;
Show messages: All  1-2  3-6
