Flow and add points issue
All  1-4  5-10
10438.5 In reply to 10438.4
Hi Matadem, you can't show points on a solid where the "underlying surfaces" are not made up of the same points where they have a joined edge.
There is some additional description of this on the FAQ here:
https://moi3d.com/faq#Q:_Why_does_show_points_work_for_some_objects_but_not_others.3F
If you use Edit > Separate to break your object into individual surfaces you should then be able to show points on the separate surfaces.
10438.6 In reply to 10438.4
Damned you have found a tutorial that i have not translated! :)
(will be made tomorrow)
https://moiscript.weebly.com/batteur-doeufs.html
Else for your problem
I have not seen the tuto but you can make something like this
- Create the curvated surface (Revolve a Profil)
- Copy Move it above
- "Flat" it with the Edit Frame
- Draw the little objects anywhere you want on this Flat surface
And use the Flow function
(Select Objects, Click the Flat Surface, Click the curvated Surface --- Rigid (else little objects will be deformed)
& VoilĂ  ! :)
(here just the Flow) here the file 3DM if you want see before after https://moiscript.weebly.com/uploads/3/9/3/8/3938813/heads.3dm
EDITED: 6 Sep 2021 by PILOU
10438.7
Got it!
Deleted the bottom part could see the points, had a flow issue but I did not checkmark the projection option.
Now to the next tutorial.
Thank you!
French translated Tutorial done! :)
https://moiscript.weebly.com/pomme-douche.html
EDITED: 7 Sep 2021 by PILOU
10438.9 In reply to 10438.8
I think that the user Mike "K4ICY (MAJIKMIKE)" has created the BEST Moi tutorials I've ever seen online (everywhere) :)
10438.10 In reply to 10438.9
... "I think that the user Mike "K4ICY (MAJIKMIKE)" has created the BEST Moi tutorials I've ever seen online (everywhere) "
Agree Marco.
Mike - come back and make more ! :)
Show messages: All  1-4  5-10
