Flow and add points issue
All  1-2  3-10
10438.3 In reply to 10438.1
Hi Matadem, I'm kind of surprised that worked ok for Mike previously - it's a situation that is problematic for Flow because of the central collapsed-together point. The way Flow works is when it is sampling the objects to be deformed, it finds the closest point on the base surface and then evaluates that on the target surface. With a collapsed central point there is an entire edge of the base surface that's all on the same point.
Maybe an approach that could be reliable would be to form a cone with a little opening at the center both for the piece being deformed as well as the base surface. For Flow you can't trim out the opening it has to be part of the underlying surface structure so something like revolve a line that's a little distance away from the revolve axis.
10438.4
Thank you for the responses.
Moving along with the tutorials I came across some I could not recreate...not important to finalize ..however important to understand imo.
With the showerhead tutorial > http://moi3d.com/forum/index.php?webtag=MOI&msg=4673.1
Although I did it a bit different I am still trying to understand why the 3d made showerhead does not show the points.
I had made the 3d showerhead shape with revolve( also tried it with rail revolve to see if I can enable to points)
I used unwrap curve of the shape then rebuild with 6 points, create a cirlce with 12 points, rail revolve then show points.
In the tutorial instruct to click show point on both items...it's a no go for me on the 3d model.(no points).
My way of doing it to show something similar to the one of the tutorial is:
draw a line then rebuild with 6 point ,create a circle rebuild with 12 points ,rail revolve then show points.
Then the only way I could recreate some thing similar is to the move the points to kind of recreate the shape as attached showerpoint file.
Let me know what I am doing wrong here.
Thank you!
Size: 455 KB, Downloaded: 41 times, Dimensions: 819x505px
Size: 679.2 KB, Downloaded: 42 times, Dimensions: 1107x716px
10438.5 In reply to 10438.4
Hi Matadem, you can't show points on a solid where the "underlying surfaces" are not made up of the same points where they have a joined edge.
There is some additional description of this on the FAQ here:
https://moi3d.com/faq#Q:_Why_does_show_points_work_for_some_objects_but_not_others.3F
If you use Edit > Separate to break your object into individual surfaces you should then be able to show points on the separate surfaces.
10438.6 In reply to 10438.4
Damned you have found a tutorial that i have not translated! :)
(will be made tomorrow)
https://moiscript.weebly.com/batteur-doeufs.html
Else for your problem
I have not seen the tuto but you can make something like this
- Create the curvated surface (Revolve a Profil)
- Copy Move it above
- "Flat" it with the Edit Frame
- Draw the little objects anywhere you want on this Flat surface
And use the Flow function
(Select Objects, Click the Flat Surface, Click the curvated Surface --- Rigid (else little objects will be deformed)
& VoilĂ  ! :)
(here just the Flow) here the file 3DM if you want see before after https://moiscript.weebly.com/uploads/3/9/3/8/3938813/heads.3dm
EDITED: 6 Sep 2021 by PILOU
10438.7
Got it!
Deleted the bottom part could see the points, had a flow issue but I did not checkmark the projection option.
Now to the next tutorial.
Thank you!
French translated Tutorial done! :)
https://moiscript.weebly.com/pomme-douche.html
EDITED: 7 Sep 2021 by PILOU
10438.9 In reply to 10438.8
I think that the user Mike "K4ICY (MAJIKMIKE)" has created the BEST Moi tutorials I've ever seen online (everywhere) :)
10438.10 In reply to 10438.9
... "I think that the user Mike "K4ICY (MAJIKMIKE)" has created the BEST Moi tutorials I've ever seen online (everywhere) "
Agree Marco.
Mike - come back and make more ! :)
Show messages: All  1-2  3-10
