Flow question
All  1  2-4
10429.2 In reply to 10429.1
Hi Art, for the project method, you can use Edit >Trim to cut the surface up into separate surface fragments, and then extrude the surface fragment. See here for some links to examples:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9335.2
For the Flow method I would need to see your .3dm model file to be able to help with that.
10429.3 In reply to 10429.2
Eggxellent Michael, worked like a charm and thankyou for the links. All that I needed to modify was the seem location on the surface below the letter "A" as it broke the ability to extrude the "A". I simply rotated the main tire 45° and proceeded with the trim procedure.
10429.4
Looking ready to hit the road! :D
Show messages: All  1  2-4
