lightwave export and units
All  1-2  3-8
1042.3 In reply to 1042.2
Michael-
That would be fine with me, if it is worth the time to implement. It would be a convenient option, but not an absolute necessity. It is easy to scale in LW or MoI (I find MoI easier). It just seemed strange to me to have both programs defaulting to inch units, and winding up with everything in meters.
Thanks for you quick attention!
nathan
1042.4 In reply to 1042.3
Hi Nathan, I am trying to avoid making very many changes right before V1, but this one happens to be a pretty easy one.
I don't have LightWave over here though, so can you please test it to make sure it works properly?
You can grab a new patch from here: http://moi3d.com/beta/LWO_units_patch.zip . That will unzip to a new moi_lib.dll file which you need to copy over top of the old version in C:\Program Files\MoI beta Sep-4-2007\ .
Then you need to open up the moi.ini file with a text editor like notepad. You should be able to find the moi.ini file here: C:\Documents and Settings\ [your login name] \Application Data\Moi\moi.ini
Add these 2 lines to the very end of the file:
[LWO]
ScaleToMeters=y
With that stuff in place, then when you export to LWO your objects will be scaled to be converted into a meters unit system inside the LWO file which it seems like LightWave was expecting. Please let me know if this seems to be reversed or doesn't work as expected...
Thanks!
1042.5 In reply to 1042.4
Michael,
I think it works. I attached screen shots of my test in case you need them.
Thanks!
Nathan
1042.6 In reply to 1042.5
Hi Nathan that's great! You're welcome!
One less step for your exports...
1042.7
Thank you very, very much for this fix. This helps me tremendously as I am rendering alot of parts that will be made for production. Here is one of them, but just a clay render as I cannot show the real deal yet with logos and such.
Modeled in SolidWorks and exported as .IGES to Moi and exported to .LWO and brought into MODO....
1042.8 In reply to 1042.7
Great, I'm glad that is useful!
Maybe I should have this turned on by default instead of something that needs to be switched on, I'm just not sure if it may scale things to be rather small if people haven't set up their units in Modo or LightWave...
Show messages: All  1-2  3-8
