Group Selection
All  1-2  3-12
10417.3 In reply to 10417.1
Hi Bo, you can type in object names using wildcard characters in the XYZ input box to select similar named objects.
To do that type the Tab key first which will put keyboard focus into the XYZ input box at the bottom of the window.
Then if you type for example HEADLINER* and push Enter all objects that have a name starting with HEADLINER and followed by any characters will get added to the selection.
You can also use ? to match just one character, like LAMP_? would match LAMP_X and LAMP_Y but not LAMP_XY .
10417.4 In reply to 10417.3
Hi Michael.
It's not working for me for some reason.
10417.5 In reply to 10417.4
Hi WN, what version of MoI are you using? It was broken in V4 betas until the last one.
10417.6 In reply to 10417.5
This one.
Size: 44.7 KB, Downloaded: 41 times, Dimensions: 410x324px
10417.7 In reply to 10417.6
Hi WN, can you please post an example file where it's not working for you? it should be ok in that final v4 version.
10417.8 In reply to 10417.7
Maybe I'm doing something wrong?
I realized this way only works for named objects.
I apologize.
EDITED: 12 Aug 2021 by WN
10417.9 In reply to 10417.8
Hi WN, yes that's correct it works on named objects and your file has no named objects in it.
10417.10 In reply to 10417.9
Very nice feature, I was looking for it too, thanks!
It's just a pity that the search [in this case - SM] does not highlight assets that are locked.
10417.11 In reply to 10417.10
Hi krass,
That's intentional because the effect of locking is that a locked object cannot be selected.
I've attached a script here that you can use for this purpose though, use by typing in:
ul name
So like in your case there you'd type in:
ul DoorBox*
That should then match locked objects as well which will get unlocked and selected.
10417.12 In reply to 10417.11
Thanks Michael!
For sure this is what you need, I will try this solution.
Sorry to bother you with my little things
Show messages: All  1-2  3-12
