Resize lofted object
All
1-13
14-19
BurrMan
2 Nov 2021 (14 of 19)
10410.14
In reply to
10410.13
""""Can we have a regular grid"""""
If you create your desired rectangle then run "network", should give you your "regular grid"
You can also manipulate the point count and loft to create various grids
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Zooen
2 Nov 2021 (15 of 19)
10410.15
In reply to
10410.14
BurrMan > If you create your desired rectangle then run "network", should give you your "regular grid"
can you show me an example ?
http://moi3d.com/forum/messages.php?webtag=MOI_FRANCAIS&msg=675.6
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
2 Nov 2021 (16 of 19)
10410.16
In reply to
10410.15
You can also use Extrude with the "Set path" option to make a point grid surface:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1313.2
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Zooen
3 Nov 2021 (17 of 19)
10410.17
In reply to
10410.16
Thank's Michael that suits me!
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
BurrMan
3 Nov 2021 (18 of 19)
10410.18
In reply to
10410.17
Zooen,
Yup, I was wrong. Michael gave the answer.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Zooen
4 Nov 2021 (19 of 19)
10410.19
In reply to
10410.18
doesn't matter! Either way, even the best can be wrong.
Zooen
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1-13
14-19
