Resize lofted object
All  1-12  13-19
10410.13
One can, on more complex solids, also use the "edit frame". And all that we can do with it : resizing and rotating, partially or over the entire surface of the projection plane, etc.. Great!
I ask myself a question, can we have a regular grid? This is not the case in my example (I have to try).
Zooen
EDITED: 18 Aug 2024 by ZOOEN
10410.14 In reply to 10410.13
""""Can we have a regular grid"""""
If you create your desired rectangle then run "network", should give you your "regular grid"
You can also manipulate the point count and loft to create various grids
10410.15 In reply to 10410.14
BurrMan > If you create your desired rectangle then run "network", should give you your "regular grid"
can you show me an example ?
http://moi3d.com/forum/messages.php?webtag=MOI_FRANCAIS&msg=675.6
10410.16 In reply to 10410.15
You can also use Extrude with the "Set path" option to make a point grid surface:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1313.2
10410.17 In reply to 10410.16
Thank's Michael that suits me!
10410.18 In reply to 10410.17
Zooen,
Yup, I was wrong. Michael gave the answer.
10410.19 In reply to 10410.18
doesn't matter! Either way, even the best can be wrong.
Zooen
Show messages: All  1-12  13-19
