moi3d Can introduce texture?
All  1  2-11
10406.2 In reply to 10406.1
Modelize in Moi then export in OBJ format then import inside Sculptris! ;)
10406.3 In reply to 10406.1
Hi feirui445,
> moi3d Can introduce texture? Like Sculptris Alpha 6, it will be very cool.
Sorry, no not likely anytime soon. There are a lot of other programs that can do that for you, you need to use one of them for that. If Sculptris does what you need then export to there, or you also might try Simlab Composer it has a lot of rendering functions.
10406.4 In reply to 10406.3
It is hoped that when modeling, there are materials on the model, which are richer than colors
10406.5 In reply to 10406.4
Hi feirui445, you can modify the lighting options to get some different kinds of display effects.
There's some info on that here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5222.1
and there's a plug-in here that you can install that gives you several presets to switch between:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5222.43
10406.6 In reply to 10406.5
Thank you. What code is used to paste PNG pictures on the model? This will be a new field
10406.7 In reply to 10406.6
Hi feirui445,
There is no method available currently for pasting PNG pictures, but you can modify the lighting parameters to give the display different types of material effects (like glossy, matte, plastic, etc... as described in previous links) while modeling.
10406.8
Utilize the LIVE SERVER function in VSCode and three JS code, can be used to view MOI3D model textures. Does MOI3D have a shortcut link address? http://127.0.0.1:5500/examples/obj%20Model%20rendering.html
10406.9 In reply to 10406.8
Hi feirui445, sorry no MoI does not have a server listening on a http socket like that.
10406.10 In reply to 10406.9
Thank you, I have placed the browser on the left. I have a question. Why is there only one object displayed after obj layer protection?
My shortcut key is set as follows: moi. geometryDatabase. saveAs ('D: \ \ Threejs Model rendering \ \ examples \ \ models \ obj \ \ wall \ \ 1. obj ',' NoUI=true; Angle=5; Output=quads'); Then three reads and renders this model.
10406.11 In reply to 10406.10
Hi feirui445, I'm sorry I don't understand what "obj layer protection" means.
Maybe there is some synchronization problem where threejs is trying to load the .obj file before MoI has finished writing to it.
Show messages: All  1  2-11
