extrude error
All  1  2-8
Check if your curve is close and planar.
Only planar and closed curves can be extrude to have closed solid.
10405.3 In reply to 10405.1
Hi cad-guy, it would help if you could post the .3dm model file instead of only a screenshot.
But best guess looking at your screenshot is you probably have a little opening in the curve in this area here, I notice the vertical edge is a little darker there that's because there are 2 edges there not just one:
So in the top view go zoom in to that spot to look for an opening, that will need to get sealed up. If you need help with it please post the .3dm file.
10405.4 In reply to 10405.3
Thanks Michael. I'll look there and if I can't find it I'll attach the file.
10405.5
That was it, thanks again ;)
More to learn and look for.
10405.6 In reply to 10405.5
Hi cad-guy, I'm glad that was it!
One thing you can watch for - when you select a curve if it is a closed curve the object type indicator here will say "closed crv", if it just says plain "Curve" there as the object type then it isn't closed:
10405.7 In reply to 10405.5
Here's another Michael Gibson post on a similar matter:
8785.2 In reply to 8785.1
Hi eric, there's a CloseCurve command for MoI here: http://moi3d.com/forum/index.php?webtag=MOI&msg=2752.2 . That will make a line segment between the ends of an open curve like the Rhino CloseCrv command.
Hope that's what you were looking for!
Cheers,
Mindset
10405.8 In reply to 10405.6
Thanks Michael, I'll look out for that ;)
Show messages: All  1  2-8
