Corner point and ordinary point on curve
All  1-3  4-15
10404.4 In reply to 10404.3
Thanks Micheal,
So, this is what I do. But currently there is only the snap "on" not "Point" for the function "add pt" to a curve. Well that is enough for me by zooming a little, the precision of the location is sufficient.
I will take this opportunity to ask another question. Is there a possibility or a trick to extend an arc-shaped curve while maintaining its overall shape?
- Zooen
EDITED: 28 Sep 2021 by ZOOEN
10404.5 In reply to 10404.4
Hi Zooen
If the curve IS an Arc (see Details), then the Extend command will extend it while maintaining the proper radius. If it is just an arc-shaped curve, then I don't have an answer.
--Larry
10404.6 In reply to 10404.4
"""""Is there a possibility or a trick to extend an arc-shaped curve while maintaining its overall shape?""""
So the extend will just make a tangent offshoot...
A "trick" would be to know and create a line that is at the end of, and is as your your desired result. (Position-direction)
Then you can use blend, which will allow tangency and curvature to be maintained over distance
With history enabled, you can interactively drag and rotate to get the extended shape you want...
10404.7
A tip: to easily convert corner points to smooth points in a curve you can use Max Smirnov's DelCorners script:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6890.1
10404.8 In reply to 10404.4
Hi Zooen,
Use "add pt" on the control polygon (with control points turned on), then drag the new point over to the point marker so you can snap on to it.
Replace your arc-shaped curve with an exact arc (use Draw curve > Arc > 3pts) and then the Edit > Extend command will do an arc extension rather than a straight line extension.
You could also draw in your own custom extension using Draw curve > Freeform > Control points, make sure you have "straight snap" enabled and place the first 2 points of the new curve along the tangent line.
10404.9 In reply to 10404.5
Hi Larry,
it is for an arc-shaped curve.
10404.10 In reply to 10404.7
Hi Metin,
Decorners smooth all the corner points of a curve, I want to be able to choose the point (s) that I want to smooth into single point (s).
10404.11 In reply to 10404.6
Thanks BurrMan ,
I will try these solutions
- Zooen
EDITED: 6 Aug 2021 by ZOOEN
10404.12 In reply to 10404.8
Thanks Michael,
For the corner points, Ok I understand this is the two-step solution.
For the extension of an arc-shaped curve I used an exact arch as you suggest; indeed it is a possible solution.
- Zooen
10404.13
Hi, all
It is while making this coffee maker that I was confronted with the small problems exposed above (among others).
This is a tutorial for another software !!! But I find it interesting to compare the techniques and the tools and to find solutions with the tools at our disposal.
Finally I got out (not too bad, well in my opinion ...).
- Zooen
10404.14 In reply to 10404.13
Nicely done Zooen!
--Larry
10404.15 In reply to 10404.13
Turned out well Zooen! - Michael
Show messages: All  1-3  4-15
