Need help with a script handler for interactiveViewChange('zoomarea')
All  1  2-5
10403.2 In reply to 10403.1
Hi Ed, unfortunately I don't think it is possible currently for a script to use interactiveViewChange() in this way.
The way view.interactiveViewChange() works currently is that it posts a message and then lets the current call stack unwind and doesn't start the view change loop until when the message is processed.
I will add in an optional 2nd parameter to interactiveViewChange() to make it go into its modal loop immediately rather than posting a message, so in v5 you will be able to do it like this without setting up your own event loop:
moi.ui.mainWindow.viewpanel.getViewport('3D').interactiveViewChange('zoomarea', true);
10403.3 In reply to 10403.2
Thanks Michael - I'll use the Continue button for now.
Looking forward to Ver 5.
10403.4 In reply to 10403.3
Hi Ed,
Checking moi.majorVersionNumber might be helpful?
    if ( moi.majorVersionNumber < 5) {
        moi.ui.mainWindow.viewpanel.getViewport('3D').interactiveViewChange('zoomarea');
	while (1)
	    moi.ui.commandDialog.waitForEvent();
	    if ( moi.ui.commandDialog.event === 'continue' ) {
                return;
    } else
--Larry
10403.5 In reply to 10403.4
Good idea Larry - We'll do.
Show messages: All  1  2-5
