Snap at intersection of line and arc?
All  1-2  3-4
10399.3
Oh, that was easy. Would it be possible to use the same magic to get a tangent snap when moving a line to a circle?
10399.4 In reply to 10399.3
Hi Andre, sorry no the radial snap used for the arc drawing snap doesn't have any relation to that type of tangent snap. That would need a new mechanism in the point picker to do that so it's not something that can happen by adjusting a command script like the previous one.
There are a couple of different ways you can get the result you want there though, one way is by drawing a helper line from the center of the circle and then snapped perpendicular to the line. That will give you an intersection point at the spot you need:
Show messages: All  1-2  3-4
