2 small questions about the interface
All  1-11  12-17
10396.12 In reply to 10396.11
I work at Win 10
I have English and Russian languages installed.
After I installed the 4 beta, when working in the Russian layout, the hotkeys in mine stopped working (they used to work).
10396.13 In reply to 10396.12
Hi krass, what version beta release are you running?
10396.14 In reply to 10396.13
10396.15 In reply to 10396.14
Hi Krass, I see - that's not actually a beta version, that's the trial version.
So that problem is probably in the regular release version as well.
What happens when you have the Russian keyboard active and you make a new shortcut key, does a newly created one work ok?
You have this command who rotates each object of a selection on their pivots!
by Michael ;)
http://moi3d.com/forum/index.php?webtag=MOI&msg=8558.4
10396.17 In reply to 10396.16
// "You have this command who rotates each object of a selection on their pivots! "..
um ... About pivots and rotation
Apparently I did not explain very clearly or Google translator distorted the meaning.
I don’t need to rotate anything in MOI3d. ((
I'll try differently.
1. All objects that I create in MOI3d during export have a single pivot point. And it is located where in MOI3D the origin is.
2. If I export (for example, via FBX) two cubes, then they will have a pivot point located at the origin of the MOI3D coordinates.
And one cube and the second.
3. Essence of the problem:
I would like to have a tool in MOI that would allow assigning (setting) a unique pivot point to an object.
So that by exporting an object to another 3D program, you can get an object with a pivot point not at the origin, but where I need it (for example, in the corner of the object)
That's what it is about.
Show messages: All  1-11  12-17
