To bend an object
All  1-4  5-10
10394.5
You can even use curves for a bend, in stead of surfaces.
─ Metin
visualizer • illustrator • 3D designer — metinseven.nl
Size: 328.3 KB, Downloaded: 42 times, Dimensions: 1096x1065px
10394.6
Here's a visual curve flow example:
After performing a flow, select the resulting object and enable the History to interactively adjust the Flow result.
─ Metin
10394.7 In reply to 10394.6
That's right, thanks Metin!
But you need to position carefully the projected curve.
BTW
Where is that History enabling thing?
Size: 557.3 KB, Downloaded: 70 times, Dimensions: 1713x1313px
10394.8 In reply to 10394.7
Hi Marky,
You can activate the History here:
─ Metin
10394.9 In reply to 10394.8
Hi Metin,
Thank you.
What else, in front of my nose!
M
example of history with Flow! ;)
Show messages: All  1-4  5-10
