Sweep
All  1-4  5-8
10389.5 In reply to 10389.4
Tony -
Michael is correct. I'll add a couple of nuances:
An easy way to select the edges is to select one side of the hair blower and in the upper right of the browser, click the "Details" button. Then click where it says "10 naked edges", and then click Join in the Edit Menu. This makes a closed curve from your edges. Repeat for the other side of the hair blower.
Then draw an arc to connect the two closed curves and use it to sweep around the two closed curves. You can add points to the arc if you want to smooth out the sharp transition.
10389.6 In reply to 10389.5
Hi micheal,
in the file there are only the two surfaces ... I drew the circle by hand to make you understand ... in fact if you see it is not precise ... I drew it without being precise ... just to make it clear what I wanted to do.
I will try as you indicated and as suggested by Ed Ferguson as well.
10389.7 In reply to 10389.6
Hi Tony, so yeah you can put in an arc using arc 3pts like this:
Then prepare the rails by joining together the edges so you've got 2 long closed
curves as described above, then you can select the arc and run Construct > Sweep,
select the rails and get this result (3dm attached too):
10389.8 In reply to 10389.7
Thanks Michael
I did not like the sweep command because there was an unselected edge (I think I hide) I rebuilt the curves and everything is ok .... thanks again
Show messages: All  1-4  5-8
