Flow direction issue
All  1-7  8-9
10387.8 In reply to 10387.1
So for your case here you would pick somewhere like this on the base surface:
Then when selecting the target surface this would be the matching area that you would want to click on:
Note that you don't want to click right on the corner, it's a little bit away from the corner along one edge.
10387.9 In reply to 10387.8
thanks sir!! This helps a LOT; nowadays I literally make parts in ~2 hours from design > 3d print, Moi is a JOY to use!
Show messages: All  1-7  8-9
