Gyroid attempts
 1-16  17-22
10386.17 In reply to 10386.16
It will never be perfect, in my opinion not even with Alias, also I have seen them that many go crazy to get surface tangent to an other and sometimes for a simple bevel they take half an hour or more, and they are professionals users, however I found a way to do it with FreeCAD and uses only one nurbs patch, a totally different method from Moi3D but I am already satisfied because I managed to do it with a decent transition now, with the NSIDE command, before it could not execute the command without surfaces.
Below the try with FreeCAD and the control point in Moi3D it's a bit messy
10386.18 In reply to 10386.14
Many thanks Pilou for your input. I was able to install FerrariSketch on WIN 10 - SketchUp 2021
but did not yet succeed to generate the gyroid surface. I think it would help a lot if you could advise me on your
input data with your set up, namely for:
Installing pressure/Warp/Weft tension ratio/Warp orientation/Default edgecable tension/Subdivisions/Accuracy level ???
I assume that the closed boundary has to be treated as rigid ?
By the way this link helped me a great deal to overcome the installation problems !:
https://sketchucation.com/forums/viewtopic.php?f=323&t=32380&p=286311
big thanks for your helping hand
regards
Ken
10386.19 In reply to 10386.18
Yes seems the Ferrari has some little difficulties with this circonvoluted Gyroïd! :)
10386.20 In reply to 10386.19
Many thanks Pilou: would you like to post your gyroid solution ?
Ken
10386.21 In reply to 10386.20
Little difficulties = no success! (with some number of trys, change parameters etc...
Even with only 2 arcs... :)
EDITED: 11 Jul 2021 by PILOU
10386.22 In reply to 10386.21
Many thanks Pilou, I didn't succeed either with FerrariSketch but the Soap Bubble plugin
worked perfectly, imho...
attached a screenshot + dxf-file of the closed boundary for further testing
regards
Ken
Show messages:  1-16  17-22
