Telephone cable
All  1-3  4-5
10382.4 In reply to 10382.1
Hi Tony, you should check out those tutorials above but the fix for your case there would be to use Flow just on the path curve and then do the sweep, instead of doing the sweep first and then the flow afterwards.
That would then avoid the compression and expansion that you have noted.
10382.5 In reply to 10382.4
Thanks Michael
I remember you told me before but I forgot :)
Thanks also to Zooen and Pilou for the tutorials;)
Size: 251.5 KB, Downloaded: 68 times, Dimensions: 1255x1019px
Show messages: All  1-3  4-5
