Telephone cable
10382.1
Hi guys,
I wanted to create a telephone wire, my attempt is to create a helix, then sweep and finally Flow to adapt the helix to the destination path ... I have deformations in the final shape ... how can I fix?
Size: 152.3 KB, Downloaded: 90 times, Dimensions: 1159x677px
10382.2 In reply to 10382.1
10382.3 In reply to 10382.1
http://k4icy.50webs.com/tutorials/Hellical_Cords.html
Zoen goes more speedy than me, but with mine you have some numerous other! :)
10382.4 In reply to 10382.1
Hi Tony, you should check out those tutorials above but the fix for your case there would be to use Flow just on the path curve and then do the sweep, instead of doing the sweep first and then the flow afterwards.
That would then avoid the compression and expansion that you have noted.
10382.5 In reply to 10382.4
Thanks Michael
I remember you told me before but I forgot :)
Thanks also to Zooen and Pilou for the tutorials;)
Size: 251.5 KB, Downloaded: 68 times, Dimensions: 1255x1019px
