Offset faces in one go
1-6
7-26
27-31
Jfs (PAQUICINNO)
24 Jun 2021 (27 of 31)
10376.27
In reply to
10376.26
Hi Michael, the inset trick works perfectly, just simple and easy. Thank you all.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Jfs (PAQUICINNO)
24 Jun 2021 (28 of 31)
10376.28
In reply to
10376.27
And what's great is the opposite result with a negative value in the height field. An easy way to extrude some tricky faces of a solid.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
BurrMan
24 Jun 2021 (29 of 31)
10376.29
In reply to
10376.28
""""""""" the opposite result with a negative value in the height field"""""""""""
There is also an inwards/outwards toggle in the command.
And when you choose outwards, a different field activates called "Expand".....
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
BurrMan
24 Jun 2021 (30 of 31)
10376.30
In reply to
10376.29
Made a quick doodle with Offset.... Just dropping this here...
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Frenchy Pilou (PILOU)
24 Jun 2021 (31 of 31)
10376.31
@ Burr Cool Subdiv modeling! ;)
For the French Tips & Tricks! ;)
https://moiscript.weebly.com/trucs-astuces.html
somewhere on the page dedicaced! :)
EDITED: 24 Jun 2021 by PILOU
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
7-26
27-31
