Offset faces in one go
 1-4  5-24  25-31
10376.25 In reply to 10376.24
So i just revisited the inset command with regards to what i just said.
So the initial inset and value, just combines both the depth and border as a single value.
Then use separate height adds the separation between the 2.
The grove value uses to 2 separated just like the first choice, but loses the initial "slab depth" value, and ability to separate that out... the grove is controlled by the separate height and groove values. The initial thickness value is missing
And what a complexity when it's applyed to just adjacent faces! Internal / external! :)
10376.27 In reply to 10376.26
Hi Michael, the inset trick works perfectly, just simple and easy. Thank you all.
10376.28 In reply to 10376.27
And what's great is the opposite result with a negative value in the height field. An easy way to extrude some tricky faces of a solid.
10376.29 In reply to 10376.28
""""""""" the opposite result with a negative value in the height field"""""""""""
There is also an inwards/outwards toggle in the command.
And when you choose outwards, a different field activates called "Expand".....
10376.30 In reply to 10376.29
Made a quick doodle with Offset.... Just dropping this here...
@ Burr Cool Subdiv modeling! ;)
For the French Tips & Tricks! ;)
https://moiscript.weebly.com/trucs-astuces.html somewhere on the page dedicaced! :)
EDITED: 24 Jun 2021 by PILOU
Show messages:  1-4  5-24  25-31
